Gen2 always blows hot
ramdough
1,729
Austin, Texas
My Gen2 always blows hot….. really hot.
My guess is the valve is allowing water to always pass.
Any suggestions?
I am thinking of adding a 5/8 ball valve.
Can anyone confirm the size?
Ronmar
7,428
Port angeles wa
Any suggestions?
Or it could be the control cable or lever on the valve is disconnected/broken? I believe that is correct on size, you can see the hoses where they pass up behind the grill, up above the radiator when the cab is tilted. On my A0 The heater plumbing/valve is the same size as the pipe where the supply hose connects on the back side of the thermostat housing…
GeneralDisorder
5,186
Portland, OR
The gen 2 HVAC box is all servo controlled. Make sure none of the air lines from the emergency/park brake control are interfering with the operation of the servos immediately under it.
ramdough
1,729
Austin, Texas
I was just wondering where those actuators are for that reason. Thanks. I will look today.
ramdough
1,729
Austin, Texas
I looked in there. My air line run to the rear of the truck side of that valve then under. I can see well enough to tell if it is touching.
Is there an outer component of the actuator that actually moves and can be blocked from moving? From the drawing and my restricted view…. I can’t tell.
GeneralDisorder
5,186
Portland, OR
Hard to tell from those pictures. The actuators can definitely be interfered with from what I recall. I routed my air lines through that mess on the bench before I installed the whole console into the truck so I could ensure they didn't interfere with any of their operation.
ramdough
1,729
Austin, Texas
Anyone have a Gen2 that is not installed that they could take a few pictures of the back of the actuator for heat? It should be the one that is on the heater lines (others are for dampers).
