Generator Accessories
Daybreak
2 Star Admiral
1,522
775
Va
Howdy,
slide hammer
slide rod driver/puller rod
5120-01-013-1676 SLIDE HAMMER, GROUND 13226E7741
ground rod, knuckles, ground strap, drive head bolt
5975-00-878-3791 RODS, GROUND SECTIONAL 9FT AA-55804-III-B
5975-00-794-2523 COUPLINGS, (THREE IN SET)
5975-00-924-9927 DRIVE/HEAD STUD
remote 55gal/5gal fuel pickup adapter
2910-00-066-1235 ADAPTER ASSY, FUEL DRUM 13211E7541
7240-01-337-5269 FUEL CAN, OLIVE DRAB
7240-00-177-6154 FLEXIBLE SPOUT
aux fuel supply line
4720-00-021-3320 or 4720-01-469-7057 HOSE ASSEMBLY, NONMETALLIC
Oil drain elbow
4730-00-809-9703 ELBOW, PIPE TO HOSE MS24519-9
trailer grounding stud
5940-00-021-3321 GROUND TERMINAL STUD MS39347-2
6awg braided copper ground
carbon dioxide fire extinguisher
4210-01-361-6921 Fire Extinguisher, CO2
Hammer
5120-00-251-4489 Sledge Hammer, 8lbs.
Trailer Mounted Accessories Box
Genset accessories.jpggenerator accessories.jpgslide hammer.jpgground ros and knuckles.jpgfuel can adapter.jpgadapter in MFC.jpgaux fuel line.jpgoil drain pipe to hose for trailer 1.jpgTrailer grounding stud 1.jpgground wire.jpgAmerex 322.jpg8lb engineers hammer.jpgGenerator Accessories Box.jpg
Zed254
468
S. Hampton Roads, VA
I bought one of the generator trailers out of Letterkenny recently and was surprised to discover a box of tools was included. This worked well for me because I haven't received anything except 1 aux. fuel line with the 2 generators I've purchased.
The tool box had just about everything except an auxiliary fuel line. There was a bag of fittings that included bolts for bolting generator to trailer, tool box to trailer, the ground stud, and 2 oil drains - 1/2" and 3/4" pipe - with hose and clamps.
Also had an 8 lb sledge hammer and ground rod kit (rods, slide hammer, bolts/nuts) in it. A VERY nice surprise!!!
Sussex County, NJ
I bought one of the generator trailers out of Letterkenny recently and was surprised to discover a box of tools was included. This worked well for me because I haven't received anything except 1 aux. fuel line with the 2 generators I've purchased. The tool box had just about everything except an auxiliary fuel line. There was a bag of fittings that included bolts for bolting generator to trailer, tool box to trailer, the ground stud, and 2 oil drains - 1/2" and 3/4" pipe - with hose and clamps. Also had an 8 lb sledge hammer and ground rod kit (rods, slide hammer, bolts/nuts) in it. A VERY nice surprise!!!
I have to ask... What kind of covers did you make for the air intake grates. I'm currently wrapping mine up in a tarp, not sure if it keep moisture out or in. So far I removed one mouse nest and afraid there are more coming.
Thanks,
Erik
Sent from my XT1254 using Tapatalk
Daybreak
2 Star Admiral
1,522
775
Va
Chainbreaker
2,112
Oregon
Got any part #'s for the plastic Box Wrenches used on load terminals and which model genset load terminals they can be used on? I have looked in TM's but can't seem to put my finger on Box Wrench p/n for MEP-002a/-003a.
Chainbreaker
2,112
Oregon
Chainbreaker,
There never was any box wrench made for any MEP-002A to 007A.
Hmmm, I see box wrenches advertised from time to time on eBay that "allegedly" are supposed to fit -002A/-003A load terminals. I once bought one of those that seller advertised to fit -002a; unfortunately it was a big honker that did not fit (P/N: CTM-282 / 5120-00-138-3790). Well...I guess if they never made a box wrench to fit the -002a/-003a load terminals I should just stop looking and use a metal one.
Zed254
468
An image of the wrench from my MEP-803A is attached for part numbers. A 1-3/8 combination wrench fits the lugs. No idea if it will fit an 002a/003a. Part number is 30554 88-21146.
Guyfang
27,283
Burgkunstadt, Germany
I didn't say that some of the wrenches won't fit. I said the milatary didn't make one especially for the 002 & 003. Now if I wanted to really know, I would look at the NSN of the load terminal, in several different parts manuals, and compare that to the various TQG parts manuals. I might just do that when I am using my computer, and not this silly tablet.
Light in the Dark
6,796
MA
I think the wrench for the 802/803 works just fine on the 002/003 (I think I have used this many times on the 002 I just sold).
reset2
102
Myersville MD
I just won an 803 at Letterkenny but it only came with a terminal wrench trailer jack crank and 3 ground rod sections.
Sent from my SM-G935V using Tapatalk
DOGWOODRIDGE
jackson, la
I’m looking for the housing cover that goes over the cylinders on my MEP-002 generator. It came without one. Anyone know where I might find one?
Guyfang
27,283
Send a PM to Ray 70, and start a Want Add in the Parts wanted forum. When you post something to an old thread, often you do not get the visibility you need.
glcaines
2,817
Hiawassee, Georgia
I don't know if they have them now or not, but I got a different replacement part of the enclosure for my MEP003A from Delks several years ago. The price was very good at the time.
