Hummer Guy
- 804
- 93
- United States Louisiana
Im kind of uncertain on this, but my generator is barely charging with my 200AMP generator. The RPM gauge either goes completely off or just jump between 0-600RPM no matter what speed the engine is at. The battery gauge is also in the yellow and close to red, and I'm only getting 25v with both the truck off and running. I looked at the wires coming from the generator to the regulator and notice it looks to be in bad shape, I move the wire and then it suddenly gave out a little spark. My question is, can this wire actually cause this issue? I don't want to start splicing into this if its not the issue. (The wire is hard wire into the generator so its not no plug and play, it's more like splice and pray)
Both the regulator and generator is barely a year old.
I'm assuming this issue was caused when I wash the engine bay the other day and used a crappy gel degreaser instead of the foam one I generally use.
