dave wagner
- 1
- 3
- garland ne
this is a 10kw gas generator, the engine runs great, there are some wires disconnected from the manual governor that i think control the hz . the voltage when adjusted to 120v has an engine rpm of a little over 2000, this makes hz 74, if i manually slow the engine at this point to 1800 rpm the hz come down to 60 and the voltage stays at 120. when the throttle linkage is released the rpms go back up to 2000 and the hz go to 74 the voltage stays at120. i need help on finding what wires go where and or a tech manual .
