Hey guys!
I have a question for you:
I have a business that can't be without power, I have a mep805a and love it but it's not enough to feed full production so it's a problem. I've been thinking in getting a bigger mep, 60kw for instance that should be enough but I could also get another 805 and use them in parallel. What do you guys think is better?
Also while pondering about this I started to think, if I have a 30kw mep running at 80% load or a 60kw mep running at 30% will they use the same amount of fuel?
So in summary: capacity vs investment/operation what is better a) 60kw single genset for every situation or B) 15kw for when only office is working, 30kw for when production is low and 60kw for when you need full power (scenario B I'm shutting one off and switching for the next bigger one as demand goes up)
Also keep in mind this is still an emergency genset application and not the primary electricity source!
I'm looking forward to hearing your opinions guys!
BR
Enviado desde mi SM-G935F mediante Tapatalk
BR
