Generator
Lextreme
SGV Ca.
I did some search but found stuffs not I was looking for. I am looking for someone with experience installing a generator head unit into the Deuce engine bay. I am looking for like 5kw type of generator. Installation, wiring and brackets with pics will be greatly appreciated...
John S-B
1,048
Ostrander, Ohio
It might be easier to install a belt driven Hyd. pump and then mount the head to the frame further back under the bed and run it off the hydraulics. I know that's how our firetrucks are configured. It takes up less space and you could mount it where it won't interfere with something else. You could also possibly use a pto driven setup. Do you need it to run while driving or just when parked and running?
