kx250m1
- 0
- 0
- sturtevant/WI
just a couple quick easy questions,
what type and weight of oil do I need for:
transmission
transfer case
axles,
and will regular brakefluid work just to fill the master cylinder if it happens to be a little low, I think it would be fine, I just want to make sure
hopefully everything is full, I just want to have the oil and supplies with in case something is low, I looked at this truck while bidding, but did not check all fluid levels, but there were no noticeable leaks, and brakes had good pressure, also I am picking this up this thursday at Fort McCoy WI, and planning on driving it home to southeast WI, and hoping for no problems
transmission
transfer case
axles,
