Getting Diesel Fuel in Oil
Kozychris
Rogers-AR
I have A M52A2 LDS 465 Multifule I think it is 1962 it seemed to be in very good condition I drove it abought 30 miles runing great but getting diesel in oil and throwing it every where. it sat abought 1 year
Chevracer87
Hilliard Ohio
geting dieselfule in oil
Is your FDC bypassed? This is a common problem if it isn't. Try searching the site and you will get a wealth of knowledge on the topic.
gungearz
northwestern indiana
Other then a spelling problem that made me read your thread a few times to comprehend it.. It sounds like you have leaking head gasket... Is there any external leaks evident on the motor..? Have you dowloaded the tm's and did you use the search function for similar issues..? I wouldn't even take a chance running the motor due to possible catastrophic engine failure... Any pictures of the issue...?
1,174
I doubt it's a head gasket.
This issue has been covered 100's of times. A search should find you all you need to know(search terms, "fuel in oil")
It's either your hydraulic head poppet shaft, HH orings,shut-off slide o ring, FDC, or booster pump seal.
1,174
The manifold heater issue has been coved before as well. Very, very unlikely that it is the issue(almost impossible).
Kozychris
Rogers-AR
Well, the FDC has been bypassed already. I drained almost two 5gallon buckets of oil out of the engine. When I run the engine, it smokes. It smokes black smoke when I am driving down the highway and white smoke when it idles. It smells like diesel fuel. I have not run it all since I saw the diesel fuel in the oil.
