Ghost in windshield washer
Whit
Atlanta, Georgia
Guys:
Well thanks to all the amazing info on this site I just fixed yet another gremlin under my dash, the heater blower which had me stumped for a while.
Now I have yet another issue: When I turn the wipers on, the windshield pump also goes on. (I don't mean when I twist that flat blade on the colum designed to make both to go on at the same time). In this situation I am just rotating the wiper switch on the end of the column. The wipers come on sure enough, but the washer also squirts and won't stop until I turn off the wipers.
Have searched through the forum and not been able to find a solution.
Any help most kindly appreciated.
Merry Christmas, BTW!
Whit
Warthog
232
OKC, OK
Sounds like a dirty/broke wiper control switch. You can get a new one at any parts store.
mistaken1
Kansas City, KS
Take the cover off the wiper motor. The pump is integrated with it. There is a cam that rotates when the wiper motor is on. When you activate the column switch a coils pull an arm that allows the pump arm to catch on the cam actuating the pump. The arm is supposed to slide so that after so many strokes the arm moves over to clear the cam until it is once again actuated by the coil. The slide can gum up so that the arm does not move over and will instead continue to pump.
I lubed mine with silicone spray and made sure everything moved freely and was aligned properly.
Wolf.Dose
9
Boehl-Iggelheim, Germany
Mistaken1 is correct. Thats it.
blckdblnckl, was you wiper motor NOS. So the libricants on that are 20+ years old. Clean it, check for propper assemble, relubricate and try again.
When I had these troubles, no replacement was available. Some parts inside the pump actuation were worn out completely, which I found afte disassemble. So I added an extra tank with abottom pump from a Chrysler. Volume was only one Quart, but it worked with an extra installed push bottom.
Wolf
