Armada
- 4
- 0
- Buick City, MI
What is the thinner/paint ratio for gillespie paint? Red oxide primer and 24087. I'm brushing it today on new slats I made for my troop seats and headache rack. Thanks!!!
What effect does changing the ratio of paint:thinner have on the final result. I'm asking because I'm painting a trailer with the same paint I used on my deuce, and I think I'm using the same ratio as before, but the color has almost no gloss to it. I did scrape the can and stirred it for quite a while, but didn't take it to a store to have it shaken. I'm using 4:1 on the trailer, and still using xylene to thin it. I'm wondering if reducing the ratio to 2:1 will make it glossier?Army Jeep Parts...tip
[FONT=Arial, Helvetica, sans-serif]AJP recommends [FONT=Arial, Helvetica, sans-serif]the reduction of Gillespie Coatings with a [/FONT][/FONT]
[FONT=Arial, Helvetica, sans-serif]SYNTHETIC ENAMEL REDUCER. This is accomplished at a ratio of 2:1,
[FONT=Arial, Helvetica, sans-serif]paint to reducer. Most brands are fine, such as NAPA or PPG, etc; just as [/FONT]
[FONT=Arial, Helvetica, sans-serif]long as its a [/FONT][FONT=Arial, Helvetica, sans-serif]SYNTHETIC ENAMEL REDUCER[/FONT][/FONT]
RAPCO
[FONT=arial, helvetica]PAINT THINNING RECOMMENDATION[/FONT]
[FONT=arial, helvetica]Thinning ratio for paint & primer is 4 parts paint or primer & 1 part thinner. Most of our customers prefer XYLENE. If you have a Gallon of paint or primer that has set for some time, you will need to scrape the bottom of the can and put it on an agitator for a minimum of 10 minutes to ensure the proper quality. XYLENE can be purchased at your local hardware store.[/FONT]
