Kaiserjeeps
- 7
- 28
- North Idaho in the woods
Drove my Duece in a parade on Monday. On the way home (20 miles) my brakes started dragging. I forgot my temp gun but the hottest drum was the passenger rear. I could touch all the others.
Got home and the rear pass wheel was smoking from brake drag. I cracked the bleeder and about 3/4 cup of very hot brake fluid shot out under very high pressure. It was very foamy and looked like it was boiling.
This problem is intermittent and does not do it unless I drive for quite a awhile.
The airpack and master cylinder were rebuilt to convert back to DOT5 in 2004. The wheel cylinders were also rebuilt in 04 mid year.
When I feel the drag, my master cylinder pushrod seems to be sticking in the master cylinder. I can feel the slop under the pedal. Almost like a clutch pedal with free play. Sometimes the pedal is all the way up and very firm. When I have the problems it has the free play I mention.
When applying the brakes hard, it takes several seconds (4- to release and roll easy.
This happened on my last long distance parade. ALL the brakes bound up with pressure. Bleeding a wheel cylinder down got me home. Lots of pressure there.
I am leaning towards the master cylinder because it feels like it is sticking.
What do you guys think. Could it be a bad airpack since it is making pressure somehow? Or do you guys think the master is not functioning correctly?
BTW, the parade was a blast. Oregon's second largest parade in the state.
Thanks for the input on the brakes. I could shot gun it with new parts, however money is short and I would like to make it safe with out breaking the bank. ... Al.
