Give me a brake!!!!!!!
RJM27
26
Burdett NY
How does the emergency brake away device attach inside the Hydraulic unit behind the lunette?. Have plenty of pressure on Lunette ring and Fluid coming out of the bleeders, TM says to use the Brake away to pump up pressure for bleeding. Unable to get any pressure, not sure if something came unhooked or broke inside.
Thanks Bob. :lost:
blybrook
Fairbanks, AK
I was wondering this question too, and I haven't taken apart my hydraulic controller to find out for sure, but page 245 of the TM (9-2330-202-14&P) shows the guts. That may help get you on the right track.
HTH
Bill
papakb
1,184
San Jose, Ca
There's a ratchetting gear assembly on the top of the actuator that moves the cylinder if the attached chain gets pulled by the trailer coming loose from the pintle hook. By pulling on the chain you can actuate the cylinder by hand to bleed the brakes. You'll need to use a screwdriver to lift the gear latch to alow the brake cylinder to return to it's "home"position.
Kurt
RJM27
26
Burdett NY
Ok guys thanks for the help, TM 9 on page 245 fig. 10 reallyl helped out. looks like part # 20 (washer push rod left the building). Was able to make another washer work. Boy a power bleeder would be nice. Took forever to use vacum bleeder, Brakes work great now.
Thanks Again.
Bob.
