GL pics and spotting an air shift axle
LanceRobson
206
Pinnacle, Stokes County, NC
A lot of the GL pictures either don't show the lower dash clearly or are very dark. is there a way to tell from engine compartment pics if a truck should have an air shift axle?
I'm nowhere near a parts manual or a truck to look at.
Lance
jimm1009
71
Louisville, KY
Here is a picture of my truck. The chrome knobs are heater and defroster controls and the switch is just to the right of the chrome knobs.
Good luck in your search. I also sent you a PM, Scott.
Jim
1,808
Yes, if the angle is right, you can tell from pics of the engine compartment. Post up a pic.
scooter01922
42
Newbury, MA
Depending on who installed the heater kit the knobs can also be way over to the left like in my truck. Sorry for the crappy angle but i was trying to get the actual wire and air atachments for another member rather than the controls.
jasonjc
290
Gravette Ar.
Re: RE: GL pics and spotting an air shift axle
:lost:
You can tell if it has a air shift T-case from a pic of the eng compartment :? :? ???
scooter01922
42
Newbury, MA
yeah yellowbronc thats the lever, i know the original poster was asking if he could tell from the engine compartment pics but i thought i would show how the heater controls can be mounted in different positions.
1,808
If you look closely at the area just under the air governor, you can see the air line that goes down below! No air line= no air shift. As I said before, you have to have a decent pic at the right angle.
Stretch44875
Super Jr. Moderator
30
Tiro, Ohio
Stan's got a truck with the airshift lever, and a sprag transfer case. So even if it does have a switch, it may not have the airshift.
m16ty
218
Dickson,TN
Whenever I bid on a truck from the pics I always look for the switch. I guess I could end up like Stan. To be honest if I looked at a truck in person I probally would just see the switch and wouldn't look close enough at the t-case to notice it. I guess I better start looking.
emmado22
147
Mid Hudson Valley NY
If it has this copper airline running down the top/side of the valve cover,(on the right hand side in this picture. The line connects to the air govenor on the firewall) it's a REALLY good possibility it has an Airshift.. (while it is possible a truck that had an airshift had it replaced with a spag, chances are low of that happening..)
I wouldnt put much stock in the "airshift gear shift lever" thing... Those are easy to replace in the motorpool...
No airline, definately no airshift...
Here is a good pic of the airshift lever thats on the bottom of the dash...
