Glad Hand Valve & Tow Lights
LibertyDeuce
New York, NY
I have two questions. I am going to pick up a M103A1 trailer in the next two weeks.
First question. The valve handle on the deuces rear valves, in order to open the valve, is the handle parallel to the pipe or perpendicular to the pick to be open?
Second question. How do I tap the brake light circuit using using a spider harness to wire up tow brake lights?
:D
Stretch44875
Super Jr. Moderator
30
Tiro, Ohio
The valves on mine are opposite most ball valves. When the handle is parallel, it's closed, when perpendicular, it's open. Pretty annoying to someone who uses ball valves and installs them. Easy enough to find out, just turn the valve on the passenger's side, it will blow air when there is air in the tanks.
1,808
Since you asked about the valves on the back of the deuce, I'm assuming that is what you are going to get the trailer with. If that is the case, you needn't do anything with the M103 trailer other than plug it into the truck. Then again, if the trailer has no harness, it's best to get an old trailer plug and tap it. I'm not keen in splicing into harnesses unless I have to.
LibertyDeuce
New York, NY
Kenny
You always come through!!! You are AWESOME!!! Your assumptions are correct and thanks you for the much needed info and wisdom. And yes, the trailer DOES have the hook up cable.
1,808
Little enterpring shortcuts I've had to take in the past when I came less that prepared. Once hooked up if one of your trailer lights isn't working, it's not to difficult to snatch a tailight assy off the truck and swap the. Love the interchangeability of these trucks and trailers
cbvet
20
Northwest (Knox) Indiana
FYI
The gladhand valves are very common natural/LP gas shutoff valves as used in homes since about forever.
If they leak, you can usually take them apart & clean them. A little Break-Free or other Teflon lube works well on them. To stop a slight leak, you may only have to tighten the stem nut a little.
And I too, would never cut into an intact harness unless there was really no choice.
Eric
CBVET
