glow plug card connection problem
b4thundr
LaFayette, NY
ok so has anybody had problems with this? where you move the assy and one moment it will work and the next it won't ? well i tried every thing even cleaned the terminals n stuff well i took a clothes hanger pin, took it apart used the ends where your fingers go as little wedges and put them under the card to prop it up so the the connections stay tight and its been working perfect so far works every time!! oh you will have to trim the wood down to get it in the black box.
