- 260
- 79
- 28
- Culleoka, TN
So last month finally got to my 1986 M1009 "tan" I acquired from Illinois last year.
Bought it with the radiator stolen, all battery cables cut and stolen, batteries stolen and a few broke out windows.
Get it rewired and was hard to start, but started after years of sitting in the PO's lot.
I go to change out the glow plugs and all 8 had swollen tips (Autolite brand - AVOID...!!!).
Did not have the glow plug extractor tool and had to break off two of them on the passenger side. I've done plenty of change-outs and always got the broke off tips by bending them and pulling from the injector port with forceps. I bent #2 glow plug tip (I "thought") and went to fish it out. I could not find it. Go to #6 tip, push it into the pre-combustion chamber and extract it (thinking "maybe I don't really need to bend them to extract"...). Look under the CUCV, around it and inside #2 injector port - still can't find the tip...
I think, "naw, it didn't fall into the cylinder - or did it?" I put a ratchet on the crankshaft pulley bolt and sure enough the engine "stopped" during rotation. Damn...!!! Reverse direction a bit and try again - engine stopped at same location...
At this point and not owning a bore scope, I determined that the head had to come off...
So off with the cylinder head it goes and laying on top of the piston was the broken tip... I was p#ssed, but glad I didn't try to start it to "blow" it out the exhaust like I read on the 'net... I don't think the starter would have overcame the obstructing tip and would have either embedded itself into the piston or got lodged in a valve if it did start...
I learned some valuable lessons:
1. A glow plug tip CAN fall into the cylinder even if "swollen"... (there's actually enough opening for two tips side by side as the picture shows).
2. Before breaking off a tip, put cotton, toilet paper, paper towel, something below the glow plug tip to cover that damn
pre-combustion slot so nothing falls thru it...
3. Buy the swollen tip removal tool...
Hope this helps someone in the future...!!!
