kcbbqguru
- 0
- 0
- kansas city
could the glow plug controller be bad, and need replaced?got a use GP control harness and everything worked fine for 2 weeks, now it blew control fuse #17 again?
I'm going to check wires again
It's just very strange that it worked fine for 2 weeks, then started blowing control fuse?? did I get a bad harness? pm me the details on your harnesses? thanksI would definately make sure all contacts are corrosion free and CLEAN.If you find yourself with a bad harness I have a couple available.
In the back of the -20 or -34 TMs.Where do I find the diagrams?
Today, I started by just checking of couple of easy things. I unplugged the GP control harness, and put in a new fuse and now everything works, except of course the glow plugs. The glow plug harness has been replaced, could it be the glow plug relay on the fire wall, causing the it to blow the fuse?got a use GP control harness and everything worked fine for 2 weeks, now it blew control fuse #17 again?
