REDWOLF
- 0
- 0
- Risingsun Maryland
What mod glow plug is every one running in there 6.2. I think it is time to change mine and just whanted to know what the best ones are.
Thanks.
Thanks.
The part number for the 6.2 Bosch Duraterms is 80034.Current recommended one's seem to be the AC60G's or Bosch Duratherms, but I haven't seen a part number for those.
You cut the old connectors off and install the new spade connectors.doghead, where do you get "new terminals"? Do you steal em off a set of wires from the boneyard? Do you buy a whole new set of wires?
They just don't have the bakelite cover on them.They are the female end of electrical spade connectors, available at your favorite parts store.
Someone said they ground down the spade on the glowplug, I cant find the thread for it now...Question is is it still working...Sounds easier than changing all the wires. ALSO I got a set of autolite 1110 plugs from the parts store....are those the right ones ot use?????
1. Just be careful and it isn't a problem.Problem with grinding to fit terminals is
#1 you could break the post off then junk plug
#2 your on the road have to change them no grinder you cant plug them in
#3 all the replacements have the larger terminals. just change plugs and never worry about it again plug and play then!
Reason's to grind
#1 ????? cant think of anyfor about 5 bucks and another 10 min just change the wire ends!
