Glow plug module question
rfischba1
Fort Meade MD
Is there a source for a new Glow Plug module? we have replaced and tested just about everythng on this truck and still will not start. once its started it runs great. Replaced GP's, temp sensor switch, relay on fire wall, checked fuel system , no leaks. Could a bad module be the problem?
Were can I buy a new GP Controller Card?
mangus580
284
Western NY
Have you gone through general diagnostics of the glow plug system?
  • Is the glow plug relay activating when you turn on the key?
    • if so, how long is it on?
    • When its on, what is the voltage at the glow plugs?
    • have you confirmed the glow plugs are heating up?
If you really want to keep tossing parts at it - Frontline had them last I knew...
leisman7
Burlington, washington
Im also curious about this.
When testing how long should they be on?
what should volts read at glow plugs?
and are you testing from the point you turn the key with out attempting to turn the engine over?
grayw0lf
Clanton, AL
Where did you find your temp sensor switch? I haven't had much luck.
