Ackevor
- -1
- 16
- Fairview, PA
Months ago I searched the forum for a better GPR to replace the stock unit in my M1008. I came by ECHGPR110 as the better unit out there, and a couple others that people had luck with. Advance Auto, where I normally like to buy from as their online coupon codes are unbeatable, cross referenced it to a BWD brand GPR11 relay. Makes sense right GPR110 to GRP11 (searched Ford power stroke as well same part)... I guess not. It has the "S' and "I" markings. I attached a photo of the label and will leave a link here.
Anywho, I stashed the relay, plugs, and tons of other extra parts I intended to replace early summer but my restoration got the better of me and I just now got around to changing them... and its not the right one. They said I can exchange it still but they likely wont have the right one so hopefully they will let me return it.
Has anyone gotten the power-stroke relay from anywhere other than Napa and got the right one?
A quick note, my current relay does still work, I swapped the plugs and thankfully the prior owner used never seize on them and all were a breeze to remove. Half were Wellmans and the others were another brand I'm not familiar with. But after the swap and resistor bypass (thanks doghead for the tips in this post) the truck starts crazy fast with the new gear reduction starter without shaking apart.
