ida34
- 33
- 48
- Dexter, MI
glow plug relay questions.
I think the glow plug relay is going out on my cucv. From looking at the wiring diagram it looks like the relay is triggered by a negative pulse from the glow plug controller. The other small wire looks to be a ignition triggered positive that stays on as long as the ignition switch is in the run position.
Regular starter relays are triggered by a positive from the ignition switch start position. This would seem to suggest a regular starter solenoid switch can not be used.
Some posts have said that the relay is available from any auto parts store. Is it a special relay? My controller is bypassed now and is triggered by a positive pulse. I plan on returning the system to original condition using a new controller but I need to make sure everything is working before I do.
Do I need to get a glow plug relay or is there a generic relay that will work?
