Glow plug solenoid replacement
1,174
You can use whatever you want to, just wire it accordingly.
Know that relays are not all the same.
The stock system and relay has an isolated ground relay. It is activated by grounding the relay coil(as the coil is isolated from the mount).
So, with the stock system wiring and relay, simply momentarily ground the light blue wire to ground and the relay should activate.
No need to remove any of the original wiring to do this.
mmcwill56
North Olympic Peninsula, WA
I'm trying to field wire this and get driving again . New elec fuel pump a plumbing from tank forward, new fuel filter base plumbed in and old steel lines removed, dog head done, fuel pump wired grabbed a hot off the fuse block single pole switch fused and grounded at pump. Been living in it for 3 weeks and at these repairs for 16 days, no shade on the asphalt here in Napa with temps into the 100s. I pulled the rectumfriers off the fire wall. Can I wire it direct from the front 12v battery to the 12v buss next to the solinoid?
