glow plug temp switch
1,174
If you look at the -20P, it has the part number listed(many are GM numbers!) . If you google the number, you will find the sensor is available but it comes with a new end that needs to be spliced in.
If you did a search here, you would also find this info. http://www.steelsoldiers.com/search.php?searchid=500113
here's the part number from the TM, 10045847
Final answer, found in one of the threads that came up with the search, for the number from the TM. http://www.steelsoldiers.com/325494-post7.html
