- 2,186
- 88
- 48
- Zimmerman MN
If they are bad, would the resistance be high or low or can be either way? Just curious. Of the 6 I tested they were all about 1 ohm which is in range from what I've read.
I started using the recommended starting procedure (wait light out, foot on throttle when starting, half or all the way, depending on temperature) for a week or two and it seemed to take longer to start than the old method I was using (wait light out, foot on brake instead of throttle, quick blip of the throttle once its started just to kick it into fast idle) so I just went back to the old method. Not sure if this would help you or not.Should I just replace them all to be on the safe side? I mean it's not that spendy at $65 or so. Another must do? My wait light seems to be work properly, longer when colder but still hard starting, lots of starter time. I see guys saying their engine just lights right off, mine takes a good 10 seconds or more of cranking.
