- 1,845
- 51
- 48
- Berkeley CA
I have an M1008 as well as two other MVs so I want
to be able to jump my other MVs with my CUCV and visa versa.
I also like the idea of feeding my glow plugs from the 12 volt bus to avoid possible problems with cascade.
My idea is to use a single pole double throw knife switch to switch between the 12 volt bus and the
resistor bank to feed the glow plug relay.
Normally it would be switched to source from the 12 volt bus. Then if I need to get jumped from one of my other MVs I can switch to the resistor bank.
All comments good or bad are welcome.
