2deuce
- 147
- 63
- portland, oregon
My sons M1009 has an issue of the glow plug solenoid not turning off when it should after startup.
1)First the truck would not start unless you gave the solenoid a whack. That told me it probably wasn't making good contact inside and we needed a new one. Got a cheap one off ebay and it didn't work out of the box. They replaced it with another that does work but....
2)Usually when cold we get the after glow a couple of times as the truck warms up. As the solenoid turns off for the last time it flutters making a buzz type sound. I'm thinking that the voltage supply to the solenoid has lowered to a point that the solenoid doesn't know whether to turn off or on and does both very fast for about a second. While I don't think this is normal in any way, I wondering if power to the solenoid is supposed to drop slowly/gradually or turn off positively, and on the same way, because it appears that this is not happening.
3) Today the glow plugs stayed on a long time after up, probably close to a minute. Then they started to turn off and on many times becoming more rapid until I again got the flutter/buzz and then they were off and stayed off.
This truck has the resistor bypassed and the fast idle does not work, making it already harder to start than it should.
I don't understand the action of the glow plug card and the temp sensor and how power is sent and regulated to the solenoid. I'm thinking of going to a manual setup, but I'd like to understand this system better. If someone can explain what is going on here, that would help in my understanding.
