Glow plulgs cycle after engine is started?? Why
rdragoo
My glow plugs seem to cycle once or twice briefly during a cold start after the engine has already began running. Is this normal? What tells the glow plug controller that the engine is running and GP operation is no longer needed? thanks to the group.
rdragoo
That all makes sense. I guess I was worried that GP operation with the engine running would damage the glow plugs.
ARMYMAN30YearsPlus
Parkville, MD
Mine Cycle in both my 6.2 CUCV and my 6.5 Suburban with no ill effect, Mike hit this right on the head as the plugs are designed to withstand the extreme temps and pressures of combustion. If they stayed on without regulation that would be bad as they draw a lot of current and they would burn out.
CUCVFAN
Gunner's Mate First Class
54
Jarrettsville, MD
It was almost a "cosmetic" thing to help reduce the white smoke on start-up by warming the chambers up quicker. Civilian trucks do it too.
