I got my relay from Checker (Schucks, Kragen, O-Reily)... I just asked for a glow plug relay for a 1996 Ford F350 with a 7.3 Powerstroke. Any chain parts store should be able to get you that one.
The Military relay is
GLOW PLUG RELAY
NAPA - ST85
Or
Ford Powerstroke relay
NAPA - ECHGPR110
It's hard to know what terminal is top on your relay, but if the wire goes to the resistor block on the firewall, you should have ~28VDC with the relay open. 26 sounds fine.
Did you try grounding the small terminal with the light blue wire on the relay to see if it closes? If the relay closes, the voltage should drop from ~28VDC to ~12VDC once the plugs warm up. Don't keep them on for more than 15-20 secs so you don't burn them out.
Does your WAIT dash light come on with the ignition? If so, check the location of the small orange wire on the relay. The TM wiring diagram is incorrect so the last mechanic to change the GPR may not have put it back correctly. The small orange wire should be on the glow plug side of the relay, not the resistor side. The relay will not energize with the orange wire on the wrong side.
Later,
Joe
