GM 10.5 14bff 4.56 gears - rust on ring gear - standard or thick gears as replacement?
McLovin
Hey guys,
I bought a GM 10.5 14bff with a detroit locker in it and 4.56 gears, which was in a M1008, for my M1009.
Disassambled it and saw rust on one of the teeth :(
I want to rebuiuld it, so it doesnt make sense, to run it with rusted gears, so I need to order new gear set (want to stay with 4.56).
Which gears are the right one for this axles, standard or thick ones?
Thank you
cucvrus
10,094
Jonestown Pennsylvania
OK. I seen the rust on the gears. Clean that rust off and add new oil and run them gears. These are heavy duty gears in these trucks. If you feel the need to change anything have the bearings changed and polish the gears. The rust you are showing is nothing in comparison to some of the gears I have seen over the years. If they are chipped and broken different story. But they will run as long as the truck is running even under extreme use. Spend the money getting the axle housing cleaned up and painted. New oil after polishing and you will be golden. Good Luck.
