Chuckanut
- 13
- 8
- Sunnyvale, California
Hey guys I Took my yolk off my rear axle because I was putting in a overdrive unit and I wanted to replace the pinion seal on the axle while the driveshaft was out and I marked the bolt with a paint pen and I used some carb cleaner and it came off of the splines but it was still on the bolt, but I went back to some pictures and I could pinpoint what orientation everything was in so I could put the bolt back on and the problem I’m running into is that i’m watching videos you’re supposed to put the bolt exactly back to where the paint marks lineup but when I put my boat back on the yolk fully seated is a quarter turn more than where the paint marks lineup. Is this normal did I break some thing has happened to anybody else what should I do? Thanks guys
