gmc 2.5 ton axles
bronco429scj
south lyon mi
the 2.5 ton steering axle in my bogger needed numerous parts its a 6.17 fine spline 6 lug unit.well i found another axle that looks the same but upon disassembly i realized it is not the same it has 10 spline shafts that are 1/8"smaller in diameter & its a 6.72 ring & pinion & its about 8" narrower than my other axle.the bolt pattern is 6 lug.i was hoping someone might know what this new axle is & maybe someone needs it thanks
NDT
7,505
Camp Wood/LC, TX
Sounds like it's from a WWII GMC with banjo axles. That is the only other axle made with the familiar tic tac toe pattern on the cover.
