gonna add deep pan
rickf
1,473
Pemberton, N.J.
The fluid will be fine but how are you going to drain the convertor? If you do not drain it then you will be mixing in the 5 or 6 quarts of regular transmission fluid with the trick shift. As long as they are compatible I see no problem but it is going to be close to a 50/50 mix. Kind of defeats the purpose if you ask me.
Rick
JVK12280
W. MICHIGAN
i can drill hole in convertor to drain,and pop rivet shut, or just run a 50/50 mix,just wondering what guys are running in their in th400s ?
its a lot easier to just pump trans out thru cooling lines after pan replacemt, converter is last stop before cooling system on all transmissions.
Croatan_Kid
New Bern, NC
I've run off the shelf Type F fluid in several GM autos that I've built. It works very well and delivers a noticeably firmer shift. If you read the back of the B&M bottle, it'll say meet or exceed Type F specs. Sorta sounds like it's re-labeled Type F to me. Nay-sayers will probably say it'll ruin a GM trans, etc, and I'm aware it has different friction modifiers in it, but all of my builds were complete, new, aftermarket upgraded parts.
