jasonjc
- 283
- 83
- Gravette Ar.
Working on the '87 truck, I found this in the fuel tank. The fuel is/was a dark yellow color some thing, and the truck would not idle at after a minute or so you would have to keep the RPM's up to keep it runnig. I've pulled all 3 filters and they seem pluged but you can't see anything on the outside of them. There is this gray goop stuff in the bottom of the tank 1/4"-3/8" thick it is even all over the pump. What is it??? Is it some kind of self sealing stuff?? Some bad/wrong tank sealer the did not set?? anyone see this before??
