coachgeo
- 3,404
- 113
- North of Cincy OH
where is good place on power distribution panel (PDP) or elsewhere in cab to tie to negative an item that is wired with a negative or an aux. fuse panel (aka not negative case grounded device). Know there is the 12v and 24v studs in PDP one can use to create an aux. fuse panel or wire a device too. just unsure on where in that area to pick up a negative. (or is there a stud for that in there too?) Does that negative bus bar in PDP have a way to tie into it?
