Goodyear MTR tires.....?
muttandjeeps
South Central Ky
I've got a set of MT's on the truck now, all about 80 or better percent there, question is, are the MTR's an upgrade ?
Looking for a quieter ride while staying with the 16.5 rim, thanks
Coug
4,243
Olympia/WA
Depends on your driving habits.
The MTs will last you longer but don't have the best traction on road.
The MTRs have a bit better traction but wear out faster.
For road noise, on my M1123 I can't hear the tires much because everything else is too loud
springer1981
1,149
Maine
The problem is the 16.5 in a 37" tire. There are no good road options unless you change to a 17" rim.
Coug
4,243
Olympia/WA
I like the BFG baja's which are available in load range d or e. Good traction and equally good ride even with the run flats at 35 psi. YMMV
Tradeoffs though are a short lifespan and no mud/snow rating.
Probably the best on road traction of the options though.
jrtoffroad
164
Colorado Springs, CO USA
Are you able to get any of these tires new in a 16.5? I've been planning on swapping to 17's as I couldn't find anything available for 16.5's.
I've seen some surplus tires but worry about the age. Wish they'd put the date code in the pics on govplanet.
