drbarnes
- 0
- 0
- Indianapolis, IN
Hello! I am happy to say that I am the proud owner of a 72 M35A2. I have been doing alot of reading on this site and its fantastic.
I have some questions from when I was under the truck adjusting the parking brake. First of all, I know the wear on the liners is uneven, and they need replacing. I am ordering some new pads but in the meantime, is the wear something I should worry about, or I am able to correct? The middle is worn much more than the ends on both the inner and outer pads. I noticed in the TM that the spring is pointed up and mine is pointed down, is this something that I should be concerned about?
I'll make you a great deal if you want to pick up a large quantity of 81mm's!
![truck1.jpg truck1.jpg](https://www.steelsoldiers.com/data/attachments/361/361381-11257208ce283af27f99d99ac3c16745.jpg)
Also, this doesn't look right to me, should there be a cover and plug here??
![Duh.jpg Duh.jpg](https://www.steelsoldiers.com/data/attachments/361/361311-f5ac8d3aa84624e7bd5371a6207ff970.jpg)
And here's the truck
![truck3.jpg truck3.jpg](https://www.steelsoldiers.com/data/attachments/361/361382-05b801262b81fb8ef626bc82d2572d76.jpg)
![truck4.jpg truck4.jpg](https://www.steelsoldiers.com/data/attachments/361/361383-5d132963d9974a544691193a3c4af0e6.jpg)
Thanks for any input.
David
David
