randyman
- 0
- 6
- Keyser, WV
I finally got around to getting the generator off the laundry trailer I bought about a year ago and got it running. I did a lot of searching on here and reviewing the TM's which saved me a lot of headaches. Like I said, the generator had been sitting here for a year or so and who knows how long before that. I removed the fuel tank which had a lot of crud in the bottom and cleaned it out , blew out the fuel lines, reinstalled the tanked and filled with fresh diesel and Diesel Kleen. Luckily, I don't think anybody had tried to start it with all the gunk in it. I also removed the fuel pumps to check the filters in them and found alot of gunk/varnish in them. I cleaned them up the best I could but after reinstalling them only one would pump good so I took two pumps off a parts generator from my other laundry trailer which looked to be fairly new and used them (the aux pump looked good and pumped good so I left it on). I'll try cleaning up the fuel pumps better and hopefully will have two spares. So, with new fuel filters installed and the fuel strainer cleaned, I jumped the generator with the M1028 and bled the fuel system. Then I preheated for a minute and tried to start it. After a few cranks, she roared to life. The oil pressure pegged high for a little longer than I liked but soon settled in at about 40 psi. There were a few minor glitches though. The frequency meter worked sporadically and the battery charging system didn't work. I called it a day and worked on her some more today and things went well. I tightened the conections on the frequency meter and transducer and found that I had a blown fuse in the charging system (thank goodness I checked the fuse before taking the blower cover off and troubleshooting the voltage regulator and stator according to the TM). Changed the oil and filter (added a quart of Lucas oil stabilizer) and cranked her up again. SUCCESS! Now everything seemed to be working properly-good frequency and voltage on all legs with selector switch in all three positions. The only concern I have is that the battery charging system is a little low. It SLOWLY increases to about 27-28 VDC. However, it puts out 30-40 VDC if batteries are not connected. Maybe speddmon (who I gather is the resident generator guru from all the threads I looked up on the subject) or someone else could give some insight. Like I said, all the past threads were invaluable and I just want to say thanks to all who contributed. I tried to upload pictures (jpeg) but wasn't able to because I think the files are too large. If anybody has suggestions, I'll try again.
