- 2,052
- 57
- 48
- Milford / Michigan
I have had an idle issue with my deuce ever since i got it. i have researched posts a lot trying to figure out what is going on. another member on here had the similiar issue i have with mine and he said it was his throttle stop plate. This is the little pendilium looking thing that swings with the throttle shaft was loose. so he took it off, re centered it and tightened it back up. my problem is the idle speed is fine, right at 800rpm when it is on flat ground or pointing down hill. when it is pointing up hill though, it idles much lower, maybe 650-700 rpm. Is there a process that i can visually look at the governor inside to inspect for any broken springs or something that may be causing my problem?
