- 7,406
- 2,498
- 113
- Interlachen Fl.
Just throwing it out there. I did replace my Cat hard line with the aftermarket hydraulic hose and no problems so far. Thread is just to show that the fitting that threads into the block is adjustable. Would seem if you are changing or checking your hard line the alinement of both ends come into play. Since we can not change the angle of the governor end it comes down to the engine side fitting. The engine side fitting is a adjustable angle buy using the nut on the fitting. Of course we are looking for the perfect angle that leaves the fitting to line fitting with all edges equal or good alinement as not to put stress on the line when we tighten that side fitting down.
