GP relay re-supply
camojcory
Harrisburg, SD
i have read posts on re-suppling your GP relay with 12v from the diamond shaped buss next to the GP relay so if one GP goes out it doesn't create a domino effect on the others.
i am a little confused, it seems there are two ways to do this, one involves a 6" jumper wire and the other simply pulls the wire from the resistors and uses that.
my question is do these both do the same thing? is one better than the other? and do i really want to do this as i am told it will now pull from only one battery?
camojcory
Harrisburg, SD
forgot to ask, replacing my GP relay for good measure, which GP relay is better to use? mine has a st-85 in it now, but i have read threads with guys using the GPR109. the 109 cost about half as much but doesn't mount in directly. are guys using it because it's cheaper or because it's better?
Barrman
1,730
Giddings, Texas
Mine has the resistor not only bypassed, but on the shelf in the shop. I figured if 12 volt plugs don't ever need to see 24 volts, the best way to make sure they didn't was to make only a 12 volt power supply to them.
We have had mid 20° mornings the last few days and we might see maybe another 20 that cold before summer moves back in. Therefore, I have no worries about my front battery being over worked. You living where you do need to decide for yourself what to do. Mine works great by the way.
