top_prop
- 8
- 18
- Suffolk, VA
I just completed a 12v bypass on my M1009. The military system was running fine since I started driving it in June, but I felt it would be insurance to run AC60G's and I'm planning an Air Conditioning Install this winter as I live in the deep south. So eventually the entire 24v system will go and the rear battery will be moved to the driver side. I searched high and low and haven't found one comprehensive thread, so I figured I'd post my pics here as this thread has good diagrams.
Here's what I did (and I'm a newbie shade tree mechanic... use this info at your own peril).
1. Chocked the wheels.
2. Removed the front battery negative terminal
3. Removed the rear battery positive terminal
4. Removed the cover for the 24V bus and removed the lead that ran to the resister behind the air cleaner
5. Removed the lead from the resister to the Glow Plug relay at the relay
