Grease points video from USMC
JonM934
221
Herriman UTAH
IridiumRed
37
NW MO, north of KC
Btw, just watched this video (my way of saying its still active / available). I didn't find the WHERE to grease all that useful, BUT... in the first section of the video, it has a couple tables of info on lubes (both grease and fluids). That -might- be useful to someone. I think those tables may be screen shots out of the military maintenance system. Dunno. I took screen shots of them myself, just in case it was useful down the road.
Btw, FWIW, the grease they spec out for what looks like everything on the truck is listed as MIL-G-10924F I'm not sure that i've seen that before (what the military actually recommends). Me, I'll be using Mobil 1 synthetic red... its what i've settled on using for almost everything* (I usually work on class 6 / 7 commercial trucks, particularly garbage trucks.
*I make a few exceptions for things like CV joints (which would be on cars / pickups i occasionally work on for the most part), where i use specialty CV joint lube...). + there are a few other exceptions but i've basically switched to mobil 1 synthetic red for 98% of everything... seems to be good enough generally everywhere, and not bad anywhere
