Grommet, large type, M1009 top
Warren Lovell
SAN DIEGO, CA
Hello everbody,
I'm just getting ready to paint my M1009. I removed tow weathered grommets from the left and right side of my M1009 removable top. Does anyone know where I can find new grommets? There look to be nearly 1.5" dia and approx 1" deep.
Warren Lovell
San Diego
sawgunner1
Knoxville, TN
Hello everbody,
Warren Lovell
San Diego
It's a standard GM part.
The dealer should have some.
pbrstreetgang
Kentucky
What part number did you order from the McMaster Carr catalog that fits the CUCV Top hole? Is there a grommet that just fills (seals) the whole. Mine lets the rain in.
Warren Lovell
SAN DIEGO, CA
After thinking I had the right one , it is not. So -I'm back to square one...and the grommet is apparently for the attenna cable to enter the vehicle.
Does anyone have any leads for new grommets?
Dodgeman1941
W. MI
This isn't original, what worked great for us, go to the hardware store and pick up hole plugs like they use with plumbing and on boats, you know, the ones with the rubber plug between the 2 washers, with the carrage bolt and wing nut. We went with the wing nut to the inside, and it's a snap to remove to run and extension cords, ect into the vehicle. Ours was just a touch big but a little buzz on an edge sander and bingo, perfect fit. PS. give the SS washer and car bolt a roughing up b4 painting or the paint will start flaking off the stainless.
Mudstone
Norman OK
again... are you guys talking about the rubber stoppers on the side of the cap... i just looked in the -20p and i can't find it.
Warthog
232
OKC, OK
They are in the -20 manual. page 439, figure 202 and the -34 manual, page 544, figure 237
If you right click and "Open Link in New Window" the picture is readable.
Mudstone
Norman OK
not to hijack but i need 1 or 2 if you can spare for both of us. Hawkman, def give warren priority since this is his thread.
Warren Lovell
SAN DIEGO, CA
i just read your post and did in fact pick up two bilge plugs that will seal out the water. they'll do until i hook up the rt524, but i carry my 3 kids in the back and the tray was removed because it interfered with kid's seating. Still looking for the correct grommets...
