Do the wires not have numbered tags on them?
Yeah, it is numbered. But something is not working. The numbers are: 23, 21, 24, 22, gnd. So I am assuming from the TM that 23 is Blackout stop lamps, 21 is the rear service lamp, 22 is turn signal. 24 then should be by elimination blackout service lamp though the TM says 20.
I took 21 and hooked it up and hooked up what I thought was ground and turned on the service light, got nothing.
I took 22 and hooked it up and hooked up what I thought was ground and turned on the service light, got nothing.
I took 23 and hooked it up and hooked up what I thought was ground and turned on the service light, got nothing.
I took 24 and hooked it up and hooked up what I thought was ground and turned on the service light, got nothing.
So I guess I need to see if they work at all or they are bad. (which I doubt)
Either I am not getting power back there or my ground is bad.
