Grounding MEP in pickup bed
rickf
1,631
Pemberton, N.J.
Considering that you are using this in a commercial application with people touching the vehicles you really need to go by code. I would get in touch with the local code enforcement people and also refer the the NEC book. No matter what, Code Enforcement has the final say. Keep in mind that if you decide to go your own way and someone gets as much as shocked you WILL be sued! If one of us tells you how to do it and then someone gets shocked we can be named in that lawsuit.
aredman
24
13
Indiana
Ok thanks for the guidance. I surely don’t want to get sued or one of you.
Maybe I should have asked what other people have done in a similar situation.
rickf
1,631
Pemberton, N.J.
You could have but the results in the end are the same. Anytime you are dealing with people in a commercial setting you need to have all your ducks in a row. AND all the required inspections. This way you are covered if something does happen. In this case your question for us has been answered and it is an easy enough job to do, but you are sure to need an inspection before operating. But if you have done everything required by the code then the inspection should go well. Electricity is dangerous so there are no shortcuts allowed. This also pertains to personal only use, shortcuts can kill you.
DieselAddict
2,058
Efland, NC
The reason why I was suggesting you look at that section of code is its much easier to comply if the generator is mounted to the vehicle it powers. Putting the generator in the truck changes how you have to do things.
You'll need to look at NEC and local codes. It could be a good call to discuss with the local inspections department and/or an ele-chicken that knows the local codes.
