Guage install question
CROM
Des Moines, IA
Have any of you guys installed a tachometer or an engine temp guage in your M1009/M1008? I'd like to monitor both measurements, but am not sure where to find guages that would install or how to wire them.
OL AG '89
9
Kingwood, Texas
Several old posts on this subject. Have you done a search yet?
The tach for the diesel is available at any parts store or on-line.
Need to specify Diesel Tach.
Which engine temp?
Exhaust Gas, Oil, Water......?
Again these are just regular gauges mentioned in several other posts.
I just added a transmission gauge to mine, still looking for T fitting to tap into trans lines.
Good Luck DO the search!!
1,176
I just did an Advanced Search for Tachometer, in the CUCV forum. Here the results.
Steel Soldiers::Military Vehicles Supersite - Search Results
How did you search?
I have an Autometer tach that uses a sensor that is installed on the Alternator. It requires calibration. I used a Kent Moore Tach-n-Time tach to calibrate it.
Your easiest installation, would be a "Tiny Tach".
1986Blazerk5
Brighton,MI
I added oil pressure and water temperature, I think its good to have both, as for the tach autometer makes a good one but its around 140 but I heard it works great there is a guy on here the installed one and it looks and works great.
