GVWR M936 Wrecker
Augdog1964
15
Richmond, IN
Ok, I'm doing my SF97, but my data plate is totally black, never punched during the last reman...
SO, I have M939 series TM 9-2320-272-10... in it is says the M936 weighs 39,334 so that's my weight correct?
The Payload says 7,000 which means the GVWR would be 46,334?
Thanks! Man, and you guys think tanks are lots of work!
nf6x
Feral Engineer
1,630
50
Riverside, CA, USA
Here's an excerpt from the Transportability Guidance (TM 55-) for the M939 series. It specifies a 7000 pound payload less crew, and indicates to add 600 pounds for the crew and their equipment. So, I'd call the curb weight 37,600, and the GVWR 37,600 + 7,000 + 600 = 45,200 pounds. The numbers may vary if your truck is an A1 or A2.
