H1 viscous clutch fan retrofit
DREDnot
435
Phoenix, AZ
Since I need to change out my stretched out wobbly belts and refurbish the cooling system, I was thinking about getting rid of the overly complicated hydraulic fan clutch system and replace it with a conventional viscous clutch.
I still get annoyed when that loud assed thing kicks on.
I read the archived posts and got the part numbers for the H1 application. I was able to get an NOS clutch but the H1 plastic conventional(CW) rotation fan is on worldwide backorder.
I was able to find a plain jane steel fan assembly. 19" six blades. made by Derale.
Any thoughts, tips or warnings from anyone who has seen or done anything similar?
I plan on starting in the next week or two and will post the results of this test.
86humv
493
Texas
Civilian H1 from 92-94 had V belts and Fan [ 5939560 ]..clutch [ 5939545 ] both discontinued.
Civilian late 94 started using surp belt system with Fan [6003064 ], and clutch [ 6003082 ].
V belt turns opposite of surp system.
DREDnot
435
Phoenix, AZ
If you use a piece of 1/2" pipe it will center everything nicely.
Ive read that bit of advice a few times in the archive.
And about grinding off some tabs on the WP flange(?)
I have an H1 application water pump from AutoZone and there is a centering dowel on it that fits perfect.
Im going to surmise that the MIL water pump has a different mounting flange with a hollow center and some heavy duty combat drive lugs?
Anyone got a pic or two of the bare HMMWV water pump flange?
