H140 Heater, electrical powered, multifuel
I've been working on this piece for a while now and the supervisor telling to fix it. When starting, the fuel pressure shows 15-25 psi. fuel pressure. During the Vent mode it barely moves, same as in the Heat mode. I've changed out the fuel filter, clean the fuel line from filter to pump, change the pump. With all this it still won't start. I do hear and feel a blower coming on, not sure if it;s the ventilation blower . As per the instructions, its what is not kicking on. Is there something I might be missing. Thanks Towbarman
155mm
Chief and Indian
503
Guymon, OK
FOR TESTING PURPOSE ONLY, not resposible for accidents
have you bypassed the air pressure switch
