HAC-36-V4B Climate control unit
MrShawn305
98
El Paso, TX
So someone near me is selling one of these units. It shows 10kw heat output and 38k BTU cooling. I can likely get it for about $250. Is it worth it? I would use it out here in the west texas heat for events and such so it will get used, but I don't know how good these units are. If it's not working and needs a charge, I'll have to convert it as the tag calls for 16.1lb of R-22. Any thoughts on these units? Really just trying to get people's impression of them.
Karl kostman
922
Fargo ND
I am not sure its the same unit but I had an S-280 comm shelter and it had two Heat/cooling units mounted to the top front of the shelter I didnt try to get them working nor did I test them because they needed some very different voltage for them sorry I dont remember exactly but it was like 280 volts to power these units, I am not an electrician and honestly I dont have any clue how to make voltage like these units wanted? Because of THIS I stripped them and used the enclosures for something else. Sorry I am not much help to you.
Coug
4,764
Olympia/WA
R-22 is still readily available, so I'm not sure why you would have to convert it.
MrShawn305
98
El Paso, TX
R22 was phased out 1 Jan of 2020 I believe. Or maybe it was 2019. I can't remember, but basically it is now going the way of R12. It's still out there, but they price is really high per pound. I can get 407c alot cheaper and just take the time to convert it.
Coug
4,764
Olympia/WA
I suppose that is understandable, as it allows for any work necessary in the future to be done less expensively if the system needs the refrigerant changed out/recharged again.
So how about R422b then? It's not that much more expensive than the 407c is, but doesn't require you to change out the oil, flush the system, and replace the receiver dryer. Supposedly a direct replacement with only small efficiency loss in comparison to R22.
Not trying to argue, just wondering what the pros/cons of upgrading the refrigerant other than the cost/availability factor.
(I did a nordic air 3 ton ECU last year with R-22, bought a bigger bottle than I needed in case I ever have to charge it again, so I'm good for now, but you never know what the future might bring so just trying to understand other thought processes)
MrShawn305
98
El Paso, TX
I'm not really familiar with the different refrigerants other than 12 and 134, and now 1234yf. The experience I have with refrigeration is pretty much limited to automotive / heavy duty (trucks) applications. 422b sounds like it would be a better alternative. The thought process is as follows: If it's working, don't touch it. If it's not performing like it should, evac and convert. I'll sell the R22 to help cover the cost of the 422b. Gives me an excuse to quit procrastinating and get my 608. I should have just done that to begin with instead of getting the 609 only.
